Eco on E1 gateway
Oct 16th, 2009
Anybody knows what could be happening on my E1? I have two E1's one for local calls and one for long distance calls (each one from a diferent provider)and on 5% of the calls (local and long distance)is happining ECO.
paolo bevilacqua Fri, 10/16/2009 - 09:33
  • Hall of Fame,
    Founding Member
Send "show controllers E1" and mention which exact IOS are you using.
Nicholas Matthews Fri, 10/16/2009 - 12:41
  • Red, 2250 points or more
Echo can be hard to self diagnose. Generally you have to listen to the audio streams.
You could be hitting a bug. Check out the details on this one, you may be able to confirm with show commands. CSCtb26941
-nick
