Cisco Unified CM Administration not working fine with IE8
Oct 16th, 2009
Hi all:
I had to install Win 7, that comes with IE8 and I'm having problems using Cisco Unified CM Administration as some windows are not opened and only displaying the attached pop up. When I click on "Continue to this site", it does not display it.
Ginger Dillon Fri, 10/16/2009 - 10:10
  • Blue, 1500 points or more
Hi -
I don't know if this version is supported yet, but here are some things to try:
- From IE8, go to Tools - select Internet Options
- On the Advanced tab - make sure the following are checked in section Security:
-- SSL 3.0
-- TLS 1.0
- On the same tab - make sure the following is unchecked:
-- Warn about certificate address mismatch
- On the Security tab, try adding your CUCM web URL to your Trusted Sites
- Optionally you can also try installing the certificate on your local workstation.
Regards, Ginger
