ASA 5500 Question
Answered Question
Oct 16th, 2009
Hi all,
I am new to Firewalling and the ASA products. I have a question regarding the ASA 5500 tunneling capacity. If I have an ASA 5500(at a remote site) with a tunnel established to an ISR (headquarters), what is the number of concurrent sessions allowed in this tunnel? Put in another way, what is the maximum number of computers behind the ASA 5500 that are allowed through the tunnel?
Any suggestions or information to help clarify this would be greatly appreciated.
SK
Correct Answer by JORGE RODRIGUEZ about 7 years 8 months ago
Is correct for the ASA5505 model, 10000 max connections with base license , 25000 max connections with sec plus license.
Overall Rating: 5 (1 ratings)
sadik.bash Fri, 10/16/2009 - 11:07
Thank you for the prompt response.
I would like some clarification on the difference between the:
- Max firewall connections
- Max site-to-site & remote access VPN sessions
- Max SSL VPN user sessions
Which one of these categories addresses my question? The max number of computers allowed throught the site-to-site tunnel?
Thanks again!
SK
JORGE RODRIGUEZ Fri, 10/16/2009 - 11:38
  • Green, 3000 points or more
Think of connections tcp/udp , not computers..
The overwall firewall maximun concurrent connections combining every other connections ssl, http.. etc..
Maximun site-to-site and RAs peer tunnels ( Not connections ) just peer tunnels , that inlcudes L2L tunnels and RA tunnels.
For SSL vpn users is the Maximung SSL concurrent SSL session the firewall is allow to handle.
sadik.bash Mon, 10/19/2009 - 13:16
Thanks for the prompt response!
So, the max concurrent tcp/udp connections that the ASA 5500 can handel is 10000/25000, correct?
Thanks in advance,
sK
Correct Answer
JORGE RODRIGUEZ Mon, 10/19/2009 - 13:35
sadik.bash Mon, 10/19/2009 - 13:38
Thanks in advance,
sK
JORGE RODRIGUEZ Mon, 10/19/2009 - 15:10
Sadik, yes that is correct, concurrent tcp/udp connections.
