Inside to Outside connection
Oct 16th, 2009
We have the following zones on our firewall:
Inside
Outside
DMZ
The inside contains a wireless 'guest' network (10.7.20.x/24) if I want to connect to a device in the DMZ (10.7.30.24) USING the mapped outside address 171.145.23.32, how would I do it?
I can always connect to it using the real address, but cannot connect using the outside address, is it possible from the inside to do this?
acomiskey Fri, 10/16/2009 - 10:49
  • Green, 3000 points or more
Yes it's possible but you will lose the ability to connect to it with the real address.
static (DMZ,inside) 171.145.23.32 10.7.30.24 netmask 255.255.255.255
oneirishpollack Fri, 10/16/2009 - 11:15
Sorry, I posted a reply before I viewed your post - and you are dead on.
So help me figure this out. We have a "guest" network (inside address) that uses external DNS. If I use DNS Rewrite, the "guest" network can connect to the device in the DMZ, because the DNS answer is re-written with the internal address. I cannot however connect to the outside address of the device in the DMZ from the inside.
If I add the static entry static: (DMZ,inside) 171.145.23.32 10.7.30.24 netmask 255.255.255.255 , I can no longer connect to the inside address directly, but it does translate it and I can use the outside address.
Is there a way that would allow me to use either address (real and mapped) from the inside and connect?
oneirishpollack Fri, 10/16/2009 - 11:07
Alright I added the following entry:
And now I can connect to the address from the inside. However, my inside clients can no longer connect to the DMZ device directly using it's local address. How do I get the best of both worlds?
Herbert Baerten Fri, 10/16/2009 - 13:35
  • Cisco Employee,
Use policy NAT:
access-list foo permit ip host 10.7.30.24 10.7.20.0 255.255.255.0
static (dmz,inside) 171.145.23.32 access-list foo
This way, 10.7.20.0/24 will be able to reach 171.145.23.32 but not 10.7.30.24
All other hosts on the inside will be able to reach 10.7.30.24 but not 171.145.23.32.
