DMA 7.1(3) modExportDatabase=Failure
Oct 16th, 2009
  • Bronze, 100 points or more
Under CallManager 4.1(3) using DMA 7.1(3) it doesn't export data;
going to GetStartupInfoA()
going to CreateProcessA()
going to WaitForSingleObject()
going to GetExitCodeProcess()
GetExitCode returned TRUE (success)
return value = 1
ExportDatabase, returning [Failure,Internal Windows to Windows CCM Migration: DB_TARGET_ERROR
Failure,Please refer to 'C:\Program Files\Cisco\Trace\DMA\DB\exportdb.log' and DBInstall/DBConvert.log under 'C:\Install\DBInstall' for more details.]
Nightspider_2 Tue, 02/02/2010 - 03:10
Hi All,
Same issue here. Thought it was only me.
I get both errors
Is this related to permissions issues on the SQL database?
Amre
Alejandro Cadar... Mon, 02/08/2010 - 10:02
Have you checked that all configured Locales in the Cluster are installed in the Callmanager Publisher?
Alejandro
Nightspider_2 Tue, 02/02/2010 - 03:47
Many thanks for the info everyone.
I dont think i had applied the locales on the servers.
I will add them and let you all know
Amre
