is there a way to modify the flap-values on err-disable?
Answered Question
Oct 16th, 2009
Does anyone know if that is possible to change
ErrDisable Reason Flaps Time (sec)
pagp-flap 3 30
dtp-flap 3 30
link-flap 5 10
.. the link-flap to let's say 3 flaps within 20 seconds?
thanks
Correct Answer by Edison Ortiz about 7 years 9 months ago
Rack1SW4(config)#errdisable flap-setting cause link-flap max-flaps 3 time 20
Rack1SW4#sh errdisable flap-values
pagp-flap 2 60
dtp-flap 3 30
link-flap 3 20
Edison.
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Fri, 10/16/2009 - 18:27
  • Hall of Fame,
    Founding Member
pagp-flap 2 60
dtp-flap 3 30
link-flap 3 20
Edison.
Peter Paluch Sat, 10/17/2009 - 01:05
  • Cisco Employee,
Hello Edison,
Thanks very much for your hint. How come that this command is not documented at all? I have had a look on various versions of IOS Command References for 3560 series switches and while the command is indeed available in the IOS, it was not described in the documentation.
Best regards,
Peter
tomek0001 Sat, 10/17/2009 - 10:14
Thank you, That's exactly what I was looking for.
