How to transfer Cisco IOS from computer to 4948 Switch using console
Answered Question
Oct 16th, 2009
Hi All,
How to transfer Cisco IOS from computer to 4948 Switch using console connection. Is that possible using Xmodem? Thank you for your inputs.
Thank you,
Siva
Correct Answer by Edison Ortiz about 7 years 8 months ago
Based on your post, you have an extra NIC doing nothing.
1) Connect this spare NIC directly to the switch
2) Assign an IP address to the NIC (for instance: 192.168.1.1 255.255.255.0)
3) Assign an IP address to the switchport at the switch, for instance:
interface fx/x
no switchport
ip address 192.168.1.2 255.255.255.0
4) Perform the IOS upgrade by following this URL:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_9592.html#wp305142
Edison.
Overall Rating: 5 (4 ratings)
Edison Ortiz Fri, 10/16/2009 - 12:50
  • Hall of Fame,
    Founding Member
What's preventing you from connecting this computer to a regular switchport?
Edison.
sivaprakasam81 Fri, 10/16/2009 - 13:00
The computer is in different network(public). I got two Ethernet card. One is used for Remote desktop and console port. I am not sure, how to do in this.
Thank you,
Siva
sivaprakasam81 Fri, 10/16/2009 - 13:01
Also Xmodem is not a recognised commond in 4948 ROmmon> mode.
Thnk you,
Siva
Correct Answer
Edison Ortiz Fri, 10/16/2009 - 18:19
  • Hall of Fame,
    Founding Member
interface fx/x
no switchport
Edison.
