LMS 3.1 Campus Manager - topology services
Oct 16th, 2009
Sir,
we are connect our LMS 3.1 portel thru our username & which is created on TACACS ACS. I am admin user and when I changed into map as per our network diagram.
1. our other team (users) can get same updated map when they are login thru their username ?
2. If it yes ? then pls. provide procedure how to get updated map.
Overall Rating: 3 (1 ratings)
Joe Clarke Fri, 10/16/2009 - 13:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to copy the XML files from the main account into the user directories for the other accounts on the server. These files are located in NMSROOT/campus/etc/users/USERNAME (where USERNAME is username of the user which will provide the files). Each user will have their own directory under NMSROOT/campus/etc/users. This copy has to be done manually, as there is no auto-sync for maps in LMS.
