QOS
Oct 17th, 2009
Hello, we have Cisco ASA 5505 running with IOS 8.2.1 version and using 2mbps dedicated lease line 1:1. Around 10 remote sites are connected by STS Tunnel but in the working hours users face slow connectivity during working on remote websites via local remote subnets. There is no QOS placed as yet which I want to implement QOS and prioritize the traffic according to their accessibility requirement.
Now I want to allocate 85 % bandwidth for STS Tunnel sites and rest of the bandwidth will be used for internet web sites so experts, pls. help what configuration needs to be done.
Another question: After implementing the QOS how the speed will be divide between remote sites. Take an example like if only one user works on remote server via STS tunnel then how much bandwidth will be consumed and if 10 users are working on 10 Servers in which 5 are connected with first remote site and other fives are working on separate servers on separate Remote sites then how the speed will be divide? Can anyone explain?
ray_stone Mon, 10/19/2009 - 11:30
Can you pls. show an example, if possible.
