Is OER/PfR common in production networks?
news2010a
Level 3
Level 3
Hello folks,
I am doing some lab exercises on "OER/PfR" (Performance Routing) and I am just wondering whether this technology is really practical in production? At least in the last 3 environments I worked I have never seen such technology implemented...
Joseph W. Doherty
Can't really comment whether it's "common", suspect not for serveral reasons, a couple being having both the equipment and environment that might benefit from it.
As to "practical", I've have and am using in a large production environment (multihomed Internet and multi MPLS CEs) and have found it has a few "gotchas", doesn't work exactly the way I want, and might have a problem with link flap knocking it down (at least on ATM interfaces). So there is some "pain" using it, yet I believe the benefit outweighs such pain. However, at least where I've been using it, my view is the minority viewpoint, i.e. the majority believes the effort isn't worth the pain.
5 Replies 5
Joseph W. Doherty
Hi Joseph
can you please post a working config of your OER/PFR
MC and BR routers
as i am trying to practice it for study but id didnt work with me based on cisco documentations
thank you
On MPLS CE WAN routers:
conf t
!on BCs
key chain key1
key 1
key-string somekey
oer border
local Loopback0
master x.x.x.x key-chain key1
end
conf t
!on BC/MC
oer master
logging
border x.x.x.x key-chain key1
interface GigabitEthernet0/0 internal
interface Multilink123 external
border y.y.y.y key-chain key1
interface ATM0/IMA0.1 external
learn
throughput
delay
aggregation-type bgp
periodic-interval 0
monitor-period 1
mode route control
mode select-exit best
periodic 180
end
conf t
!on Internet BC/MC - statics, not BGP
oer master
interface Serial1/0 external
interface GigabitEthernet0/1 internal
learn
throughput
delay
periodic-interval 0
monitor-period 1
no max range receive
mode route control
mode monitor passive
periodic 180
end
thank you for posting the config
i have the bellow config but it dosnt work
i mean the MC not learing any prefix !!
MC
oer master
policy-rules oermap
border 10.1.1.2 key-chain OER
interface FastEthernet1/1 external
interface FastEthernet1/0 internal
border 1.1.1.1 key-chain OER
learn
throughput
delay
periodic-interval 0
monitor-period 1
traffic-class keys protocol dscp sport
delay relative 10
oer-map oermap 20
set mode select-exit best
set mode route
set mode monitor both
MC#show oer master border
Border Status UP/DOWN AuthFail Version
1.1.1.1 ACTIVE UP 00:10:04 0 2.1
10.1.1.2 ACTIVE UP 00:16:33 0 2.1
MC#show oer master prefix learned
MC#show oer master learn list
MC#
BR
oer border
local Loopback0
master 10.1.1.10 key-chain OER
and the other BR same idea
i am running lab topology
where each BR connected to diffrent ISP router through BGP
BRs in the same AS ISP router each in diffrent AS
internally with the MC i run ospf and originating default route also i ma recieving default from the two ISP routers ( this is about routing )
any idea !!
thank you
With the understanding I'm not an expert with OER/PfR, especially with the newer PfR variant (which you appear to be testing), 3 items to consider.
First, is there traffic flowing through the routers and have you waited enough time for PfR to show it's learned info?
Second, it appears you have an OERMAP defined, but you didn't post it. You might try PfR without it and see what happens.
Lastly, I'm unfamilar with "traffic-class keys protocol dscp sport", here too you might try PfR without it to see what happens.
In other words, try the most basic PfR config first. Once you see it working, then you start to "layer" on some of its other features.
PS:
BTW, I vaguely recall having some issue with using a BGP default route to "trigger" PfR. I recall documentation notes such should work, but I too may have had an issue getting it to work. The first sample config I provided obtains BGP routes from external eBGP peers and works find. The second sample config was for Internet eBGP peering where I didn't want to take full routes and only wanted the BGP default. That config works, but had to have PfR generate its routes using statics rather than BGP. I may have needed to insert a configured default static route in addition to the BGP default. Again, I'm hazy on what problem I had with the Internet config. Do recall I had to do something to get it to work. (BTW, with the Internet connection, although full Internet routes were available, and routers were powerful enough to utilize them, with just defaults and working PfR, believed it would be a "better" implementation. As far as I can tell, it works very well.)
