Wireless Access Point hanging
Oct 18th, 2009
I have installed the AIR-AP1131AG-A-K9 ,it is connected to a Cisco 3750 PoE switch,the ISP Router also connected to the same switch.It is woorking fine....all of a sudden it is hanging up,no user is able to access the Internet.That time if I plug out the UTP cable and Plug in again at AP side,then it works fine....it happens twice or thrice a day ....What could be the probem.....Can anyone help me to resolve this issue.
Best Regards,
Leo Laohoo Mon, 10/19/2009 - 13:28
What's the IOS version of your AP?
When this occurs, can you still get access to the internet via the switch?
Did your AP crash/reboot when this happens?
iamthewaytruthlife Mon, 10/19/2009 - 21:24
Hi Leolaohoo,
The following is the needed information for you.
Product/Model Number: AIR-AP1131AG-A-K9
Top Assembly Serial Number: FOC12155903
System Software Filename: c1130-k9w7-tar.124-10b.JA
System Software Version: 12.4(10b)JA
Bootloader Version: 12.3(8)JEA
System Uptime: 4 weeks, 6 days, 19 hours, 2 minutes
Your que:When this occurs, can you still get access to the internet via the switch?
My Ans:When this happens I did not check the internet access through switch.I will check and inform you.
Your Que:Did your AP crash/reboot when this happens?
No it is not.
Please revert back to me.
Thanks and Regards,
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
