DMVPN_ is it possible to have dynamic public IP address at the HUB
Oct 18th, 2009
Hi Experts,
i have 5 sites with ADSL internet connectivity with dynamic IP addressign, is it possible to connect those sites without need to have public static address at Hub ( HO) .. no way to get static public IP address from that ISP.. so i dunno whats the solutions?
does DMVPN support that? whats devices you recommend..
please help :(
Collin Clark Mon, 10/19/2009 - 13:10
It would be an administrative nightmare. Every time your Hub IP changes, you'll have to go into each spoke and change it. Do-able but not advisable.
jan.nielsen Sun, 10/25/2009 - 07:44
If you could get the isp to map your routers mac to an ip, you could get the same address every time via dhcp.
socket2000 Sun, 10/25/2009 - 13:53
How about running something at the hub that registers with dyndns (www.dyndns.org) and use the dyndns registered name instead of the ip address in the spoke routers. I haven't tried it myself but it's worth investigating. The spokes are going to need some way of finding the hub.
Steve
