ROUTER E1 OR PABX E1 PROBLEM
cfajardo1_2
my router is coonected to the pabx thru e1. Iam suddenly getting the below output of my sh controller e1 0/0/0
sh controllers e1 0/0/0
E1 0/0/0 is down.
Applique type is Channelized E1 - balanced
Far End Block Errors Detected
Transmitter is sending remote alarm.
Receiver has loss of frame.
alarm-trigger is not set
Version info Firmware: 20090113, FPGA: 20, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (218 seconds elapsed):
3769310 Line Code Violations, 30126 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 218 Unavail Secs
HOW WILL I KNOW WHICH ONE IS FAULTY? MY E1 OR THE PABX E1?
THANKS
7 Replies 7
paolo bevilacqua
Likely cabling problem. However, you should use clock source internal when connecting PBX.
hi,
This was working for 2 months now.
Hi Paolo,
Can we say here that the e1 card is okay?
thanks
Router rarely fails.
Check cabling and configure internal clock.
one thing, the e1 configs are still intact on the configuration. doesnt this dictate that the hardware is okay?
controller E1 0/0/0
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
No.
You can do loopback tests, but in most cases it's just wasting time, because the problem is something else.
thanks paolo
