Giuseppe Larosa Sun, 10/18/2009 - 06:19
  • Hall of Fame,
    Founding Member
Hello Venkataraman,
post a sh ver of your router
have you powered off the router before inserting the HWIC?
Hope to help
Giuseppe
iamthewaytruthlife Sun, 10/18/2009 - 06:29
Hi Giuseppe,
Once I get the sh ver I will be forwarding it to you,meantime the IOS ver is 12.3,will it support?
regards,
iamthewaytruthlife Sun, 10/18/2009 - 06:39
Hi Giuseppe,
Please see the below attached SH VER out put.
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.3(11)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 06-Oct-05 06:13 by kehsiao
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
BNC-Router-c3825 uptime is 3 hours, 1 minute
System restarted at 11:17:26 UTC Sun Oct 18 2009
System image file is "flash:c3825-spservicesk9-mz.123-11.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3825 (revision 1.0) with 227328K/34816K bytes of memory.
Processor board ID FCZ0943732L
2 Gigabit Ethernet interfaces
4 Serial interfaces
3 ISDN Basic Rate interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
The router is not accepting HWIC-4T module also.
paolo bevilacqua Sun, 10/18/2009 - 08:48
  • Hall of Fame,
    Founding Member
You need to update your old IOS.
