ext mobility best practice
Oct 18th, 2009
phone config
dn - 8888
partition - internal
css - internal
device profile config
dn - 8888
css - mobile
ONCE THIS IS DONE, THE CSS ON THE PHONE ITSELF WILL CHANGE FROM INTERNAL TO MOBILE.. THIS IS THE PHONE ITSELF.
USER WANTS THE PROFILE TO BE DIFFERNT FROM THE PHONE CONFIG..IS THIS POSSIBLE?
WHATS THE BEST PRACTICE ACTUALY..
THANKS
Hythim Ali El Hadad Mon, 10/19/2009 - 01:59
  • Silver, 250 points or more
Sure possible,
You can use the profile with a different extension number
or simply let the profile 8888 and change the phone extension to *8888 and have your needed conf on both
wish this be helpful
Hythim Ali El Hadad Mon, 10/19/2009 - 08:30
Hi Celso,
you can make the device profile the main extension for your users 8888
And forward 8888 unregistered and no answer to *8888 to let the user always reachable also when he logout
using the same extension on both the phone and device profile will face you an issue later that i couldn't remember
So best practice to use different extensions
