James Hawkins Sun, 10/18/2009 - 11:56
Yes subject to a few caveats.
The 3845 must be licensed for SRST and the MoH must be streamed using multicast.
More details can be found at the link below:
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_moh.html
Typically streaming MoH from a router is used for remote sites where you either do not multicast support on your WAN or you do not want to waste WAN bandwidth transmitting MoH.
Please rate if helpful.
