Implications of enabling authorization in console
Oct 18th, 2009
Hello all,
I have read that it is not advised to enable authentication in console ports. Can any one point out the reasons for this and best practices as well? I am dealing with a 6509 with Sup 720 and IOS 12.2SX.
Thanks a lot in advance!
Nataniel
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Mon, 10/19/2009 - 01:44
Nataniel,
It's to prevent the user from accidentally shutting themselves out from
configuring the box"
In other words, what you don't want to have happen is to turn on authorization, have the tacacs+ or radius daemon be unreachable (for whatever) reason, and never again be able to get into your box. It's fine if this happens on vty lines, as long as you have a way to FIX it. Once you can't get to the console anymore, you've got problems.
~JG
Do rate helpful posts
namendoz Mon, 10/19/2009 - 03:54
Hi JG,
Isn't there an option where I can define to avoid authorization if I was authenticated, just for the case when lose my TACACS server?
Thanks once again!
Nataniel
Jagdeep Gambhir Tue, 10/20/2009 - 12:32
Hi Nataniel,
"aaa authorization console"command is disabled by default.
So authorization on console is disabled.
~JG
