VPN Cleint 4.X
Oct 18th, 2009
Hi Guys,
I have a pc which has cisco vpn client 4.x installed on it and it is behind the company's pix firewall.
What ports are required to be open on the firewall so that it will allow outbound vpn connection from the pc. Is it UDP 500 or anything else?
Tks
JORGE RODRIGUEZ Sun, 10/18/2009 - 19:58
if running code 7.x or above add ipsec pass-thru to global polciy for IPsec pass trhough
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/i2.html#wp1740887
pix-asa(config)# policy-map global_policy
pix-asa(config-pmap)# class inspection_default
pix-asa(config-pmap-c)# inspect ipsec-pass-thru
pix-asa(config-pmap-c)#exit
If PIX code 6.x you need to allow udp 500 (isakmp) , udp 4500 (nat-t) and esp protocol 50
