speeding up WAN
Oct 18th, 2009
hi experts,
we have 2 sites connected via BGP on a 10mb bandwidth link. both end can give 18ms average when ping.
On our side, is there a way to speed this up? or like LAN? What's a effective and practical way of doing this?
tnx
Giuseppe Larosa Sun, 10/18/2009 - 22:41
  • Hall of Fame,
    Founding Member
Hello Robert,
you should compare and consider the following options:
- a link speed upgrade
- deploying a solution that uses WAN accelerators like WAAS
for WAAS see
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/prod_white_paper0900aecd8051c07f_ps6474_Products_White_Paper.html
the performance gains you can get with WAAS depend on actual traffic patterns in your company.
Hope to help
Giuseppe
Joseph W. Doherty Mon, 10/19/2009 - 03:31
As Giuseppe describes, WAAS(/WAFS) technology is the way to try to mimic LAN performance across a WAN. However, with 10 Mbps to work with and 18 ms latency, you might be able to improve user perceived performance via QoS. I.e. a QoS configuration that keeps interactive/transactional traffic from being adversely impacted by bandwidth demanding traffic.
