IP Nat translation timeout question
Answered Question
Oct 18th, 2009
Hello
What does the command IP NAT Translation timeout * actually achieve?
Does this command clear any IDLE nat entries in the nat dtable that have been idle for athe period specified by this comman or does it force remove nat entriesthat have been in the table for the specified time.
I am trying to use this command for a load sharing scenario. I am thinking of using this or any other commands that would help me to clear only idle nat entries in the nat table in the case that one of my links fail.
thanks in advance
Correct Answer by Paolo Bevilacqua about 7 years 4 months ago
Not much of an issue, when a translation expires, IOS will create a new one as soon user activity resumes. The nature of web makes so that even if different ports of addresses are used, things will still work.
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Mon, 10/19/2009 - 01:55
It clears idle translations only.
In load sharing and multiple gateways scenario, it's often useful to reduce the timers. Also, try "oer" in "ip nat" command.
dehghan Mon, 10/19/2009 - 10:20
Thanks for the reply,
the thing is I am actually using this system as a pilot system and I am worried that this might cause connections such as online payments, FTP connections and so on disconnecting and resulting in user frustrtion.
I will play with the timers and see what happens
thanks
Correct Answer
Paolo Bevilacqua Mon, 10/19/2009 - 10:27
