The communication between Unity and CCM fot AA
Oct 18th, 2009
I have very basic question. I configured AA in Unity 7. the AA number is 5000. I tried to reach the AA from CCM by defining Unity as H.323 GW. but I am not able to reach any help please??
Hythim Ali El Hadad Mon, 10/19/2009 - 01:49
  • Silver, 250 points or more
To add h323 Gw
from device,
add gateway,h323
with the ip add of your unity
then create a route pattern to 5000 with the route list to the h323 gateway configured before
wish this be helpful
JustForVoice_2 Mon, 10/19/2009 - 02:20
This what I did before. but once I called the 5000 I hear fast busy tone.
can we say that the problem from Unity configuration??
Jaime Valencia Mon, 10/19/2009 - 06:27
  • Cisco Employee,
  • Hall of Fame,
    2011
WHY are you configuring Unity 7 as an H323 GW??????????????
You just need to follow the integration guide, use SCCP and there really is nothing much to do.
CTI RP, DN 5000, CFA to VM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
