Radius - Dest buf len 512 smaller then data len 759
Answered Question
Oct 18th, 2009
I would like ask the comunity about error in radius log on ACS 4.2(0) buld 124 Patch 12:
[079] EAP Message valuse: Dest buf len 512 smaller then data len 759.
Is this critical error, which deeply broke an EAP coversation between authenticator and server?
Where could I trigger the buffer lenght?
Correct Answer by Jagdeep Gambhir about 7 years 5 months ago
This is a cosmetic issue and should not cause any issues.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCsh37811
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
darpotter Mon, 10/19/2009 - 01:35
  • Silver, 250 points or more
Looks like ACS is trying to put 759 bytes into a 512 payload.
EAP should handle fragmentation, ie packaging up large blobs of data into smaller RADIUS EAP-Message attributes.
So this in itself shouldnt be a problem.
Hard to say without any context.
