CCM 7.1(2) Backup Error
Answered Question
Oct 19th, 2009
I have the following error in a log file:
Log File: 2009-10-17-11-53-06_b_mdsiccm71_ccm_ccmdb.log
Server : MDSICCM71
Feature : CCM
Component : CCMDB
Time Completed: 2009-10-17-11-59-58
Result Code : 1
Result String : ERROR
prebackup
ready for backup
required space = 11336140
df -k /tmp/db_drf_backup/ | grep -v Filesystem | awk '{print }'
ready for backup
exiting pre_db_backup
Beginning do_db_backup
command to execute /bin/touch /common/drf/db_drf_backup/drf_ontape_backup.gz
command to execute /bin/chmod 660 /common/drf/db_drf_backup/drf_ontape_backup.gz
command to execute /bin/chown informix:informix /common/drf/db_drf_backup/drf_ontape_backup.gz
Stopping CAR services prior to taking DB backup
command to execute python /usr/local/cm/drf/cdrrep/cm_car_service_deactivate.py - >> /common/drf/backup.log
Service Manager is running
Commanded Out of Service
Cisco CAR Scheduler[NOTRUNNING]
CM CAR - Services Stop Script
OS platform is: linux2
Linux platform........
CDRREP: Invoking CAR services stop script
CDRREP: Checking CAR services status, please wait ...
CDRREP: CAR Scheduler initial status is - started
CDRREP: Stopping Cisco CAR Scheduler
controlcenter.sh "Cisco CAR Scheduler" stop
CDRREP: Stopped Cisco CAR Scheduler Successfully
CDRREP: No need to stop Cisco CAR Web Service as it is already stopped
CDRREP: CAR Web Service was not running by default, CAR Scheduler stopped successfully. exit 21
Creating Ontape Backup of DB...
command to execute /bin/su - informix -c "ontape -s -L 0 | /bin/gzip > /common/drf/db_drf_backup/drf_ontape_backup.gz" 2>>/common/drf/backup.log
drf_ontape_backup created is of size [30675857]
Ontape Backup completed!
Creating Tar ball
command to execute sudo /bin/tar -cvpPf - /usr/local/cm/db/csv/products /usr/local/cm/db/xml/xml /usr/local/cm/idp /ccm/DialPlan /usr/local/cm/db/replicates.txt /usr/local/cm/db/DBPerfMon.xml /usr/local/cm/db/dblenv.bash /etc/services /etc/odbc.ini $INFORMIXDIR/etc/sqlhosts /home/informix/.rhosts /common/drf/db_drf_backup/drf_ontape_backup.gz /var/log/active/cm/cdr_repository/preserve /var/log/active/cm/cdr_repository/destination1 /var/log/active/cm/cdr_repository/destination2 /var/log/active/cm/cdr_repository/destination3 /var/log/active/cm/cdr_repository/car /usr/local/thirdparty/jakarta-tomcat/webapps/carreports/reports/pregenerated 2>> /common/drf/backup.log
/usr/local/cm/db/csv/products/
/usr/local/cm/db/csv/products/Product_355.csv
/usr/local/cm/db/csv/products/Product_45.csv
/usr/local/cm/db/csv/products/Product_36.csv
/usr/local/cm/db/csv/products/Product_311.csv
/usr/local/cm/db/csv/products/Product_207.csv
/usr/local/cm/db/csv/products/Product_20002.csv
/usr/local/cm/db/csv/products/Product_273.csv
/usr/local/cm/db/csv/products/dependency.txt
/usr/local/cm/db/csv/products/Product_47.csv
/bin/tar: -: Wrote only 4096 of 10240 bytes
/bin/tar: Error is not recoverable: exiting now
CCMDB Backup failed, unable to tar data to master agent
Restoring CAR services ...
command to execute python /usr/local/cm/drf/cdrrep/cm_car_service_activate.py 21 - >> /common/drf/backup.log
Cisco CAR Scheduler[STARTING]
Cisco CAR Scheduler[STARTED]
CM CAR - Services start script
CDRREP: Invoking CAR services start script
CDRREP: CAR Scheduler status is: 2
CDRREP: CAR Web Service status is: 1
CDRREP: Starting CAR Scheduler....
controlcenter.sh "Cisco CAR Scheduler" start
controlcenter.sh list | grep "Cisco CAR Scheduler"
['Cisco CAR Scheduler[STARTED]\n']
CDRREP: Started Cisco CAR Scheduler successfully
CDRREP: Should not restart CAR Web Service
CDRREP: Exiting car service start script. Start Success. Exit Code 0
EXITING!
----> BEGIN Standard Output
----> END Standard Output
----> BEGIN Standard Error
----> END Standard Error
Thanks for all.
Correct Answer by virverma about 7 years 6 months ago
Use freeFTPd as the SFTP and work again.
Try to expand the disk space
Overall Rating: 0 (2 ratings)
Correct Answer
virverma Thu, 10/22/2009 - 04:50
  • Silver, 250 points or more
josefina.mendez Fri, 06/06/2014 - 11:38
Hi, I'm using freeFTPd as the SFTP and I have 117Gb free on the server, but I'm still getting the same problem:
 Status:Ready
 Log File: 2014-06-06-14-09-06_b_ar-ba-c1-p1_ccm_ccmdb.log=====================================================
Server : AR-BA-C1-P1
Feature : CCM
Component : CCMDB
Time Completed: 2014-06-06-14-29-41
Result Code : 1
prebackup
ready for backup
required space = 11851581
ready for backup
Cisco CAR Scheduler[STOPPING]
CDRREP: CAR db manual purge or reload is not running. Continue with backup/restore
CDRREP: Cisco CAR Scheduler stopped successfully. exit 21
drf_ontape_backup created is of size [116409667]
Creating Tar ball
/usr/local/cm/db/csv/products/Product_30011.csv
/usr/local/cm/db/csv/products/spanish_colombia_user_locale.csv
/usr/local/cm/db/csv/products/Product_336.csv
EXITING!
