Basic setup for SPA3102
Answered Question
Hi, I've got this information from my ISP for using with VOIP but I am not really sure where to configure it on the SPA3102:
SIP-username
SIP-password
SIP-Server
Voicemail
Username
Password
Thanks in advance!
/Daniel
Correct Answer by dhames about 7 years 6 months ago
If you have your PC plugged into the yellow Ethernet port on the SPA3102, then you will need to access the device's interface by going to: http://192.168.0.1/admin/voice/advanced/
Once the GUI loads:
-Click on the "Line 1" tab.
-Scroll down until you see "Proxy and Registration" and "Subscriber Information"
That should do it.
Overall Rating: 5 (1 ratings)
Correct Answer
dhames Tue, 10/20/2009 - 10:21
Once the GUI loads:
That should do it.
