voice vlan on cisco 3548 switch
Answered Question
Oct 19th, 2009
I have a cisco 3548 switch.is it mandatory to configure the port as trunk in order to connect an IP phone?wht if i configure the command switch port voice vlan 2?
Correct Answer by Giuseppe Larosa about 7 years 6 months ago
Hello Azharuddin,
the switchport mode trunk is needed in this type of IOS/platform.
it is a question of IOS implementation you can see this command as a workaround.
newer IOS versions don't need it.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 10/19/2009 - 01:43
  • Hall of Fame,
    Founding Member
Hello Azharuddin,
if you have a C3548 XL device you will need both commands
actually when we use switchport voice vlan that is an implicit trunk or mini trunk of two vlans
Hope to help
Giuseppe
azharuddininamdar Mon, 10/19/2009 - 01:55
thanks for reply Giuseppe,
since the port carries both data and voice traffic,so it is called as implicit trunk?and will my ip phone works fine if i do not configur the port as trunk?
Correct Answer
Giuseppe Larosa Mon, 10/19/2009 - 02:01
  • Hall of Fame,
    Founding Member
Hello Azharuddin,
Hope to help
Giuseppe
