ASA latest version
Ahmed Yassin
Dear all,
My ASA version as followinf:
Cisco Adaptive Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(2)
So, if you please, can you tell me what is the latest ASA version?
And how i can get this version?
And what is its size on the flash?
As my flash is as following:
Primary-ASA-Plant# sh flash
-#- --length-- -----date/time------ path
6 8312832 Jan 01 2003 00:05:32 asa722-k8.bin
7 1868412 Jan 01 2003 00:05:58 securedesktop-asa-3.1.1.29-k9.pkg
8 398305 Jan 01 2003 00:06:16 sslclient-win-1.1.0.154.pkg
9 5623108 May 17 2007 23:07:26 asdm-522.bin
239140864 bytes available (16285696 bytes used)
Last question: applying new version doesn't affect the current configuration?
Appreciatted for your effort.
5 Replies 5
andrew.prince
Level 10
Level 10
To answer your questions:-
So, if you please, can you tell me what is the latest ASA version? 8.2.1
And how i can get this version? - you need a valid support cco account to d/l the software
And what is its size on the flash? - you have enough space
Last question: applying new version doesn't affect the current configuration? - a few minor things will be changed.
The big question is why do you think you need to upgrade?
Thx a lot of your reply.
I have enough space to upgrade without erase old version, left the old version on the flash.
Sorry, give me example for the few minor things that will be changed after applying the new version.
I upgrade as VPN anyconnect client must work with version 8 and later.
I have enough space to upgrade without erase old version, left the old version on the flash - Yes
Sorry, give me example for the few minor things that will be changed after applying the new version - I do not have the exact details, I suggest you read the upgrade notes on the specific version you will upgrade to.
Appreciatted for your cooperation.
np - glad to help.
