is annunciator supported with TP
Answered Question
Oct 19th, 2009
we have been trying to get the annunciator to work with TP but no luck
the thing is, the stup works if we use it with IP phone with SCCP
however dose not work with SIP
as TP using SIP this is why it dosnt work
the question here, is this normal i mean annunciator is NOT supported with TP yet ?
and if its supported how we can get it working ?
Thank you
Correct Answer by gogasca about 7 years 3 months ago
I tested in lab as well and no ANN, since we send a 404 Message and we no longer re-negotiate media
SIP/2.0 404 Not Found
Reason: Q.850;cause=1
Date: Thu, 22 Oct 2009 23:00:53 GMT
From: "3001" ;tag=0019aa043e5809f155224b8c-3cc13db2
Allow-Events: presence
Content-Length: 0
To: ;tag=2cbe38ed-a8e2-4bdc-bd18-7e24c7d28ef4-53366947
Call-ID: [email protected]
Via: SIP/2.0/TCP 172.16.181.57:51616;branch=z9hG4bK733fa4eb
CSeq: 101 INVITE
I see that for SIP we are terminating the transaction
10/22/2009 16:00:53.871 CCM|LineCdpc(85)dispatchKeyReleaseReq - mDevicePid(3, 47, 50); mSelectedDPid(0, 0, 0), mOnBehalfOf(Device), rfr(0)|
and never invoking Media Resources
Ths is because in the code SIPStationCdfc object, the signal for inserting ANN resources is not implemented, we just want to terminate the transaction.
In SCCP we do have that signal after call termination
002081676| 2009/10/22 16:11:32.375| 003| SdlSig | SsInsertMediaReq | wait | Cc(3,100,175,1) | StationCdpc(3,100,41,18) | (3,100,39,1).361692-(SEPGOGASCA:171.69.87.220)| [R:NP - HP: 0, NP: 2, LP: 0, VLP: 0, LZP: 0 DBP: 0] SsType= 0 SsKey= 0 SsNode= 3 SsParty= 53366949 AnnList.locale =1 AnnList.tone121 EndOfAnnAck1 MediaResourceType7annPlayMode1
As workaround use a Translation pattern XXXX and send it to an IVR or Unity and play a greeting from there
Overall Rating: 5 (4 ratings)
gogasca Tue, 10/20/2009 - 12:43
Can you please explain what is the call flow?
and what r u trying to achieve with ANN and TP ?
Marwan ALshawi Tue, 10/20/2009 - 16:18
hi the call flow is TP to CUCM
as you know TP uses SIP
the idea is to get the error msg when we dial wrong number for example instead of only fast busy ton !!
thank you
Correct Answer
gogasca Thu, 10/22/2009 - 15:21
Content-Length: 0
CSeq: 101 INVITE
