how can i prevent messenger communications
Answered Question
Oct 19th, 2009
dear experts, i'm using ASA 5520 and i want to deny the msn and yahoo messengers without affecting the hotmail or yahoo websites access, so i want to know the specific ports which i should deny and on which transport layer protocols (tcp or udp), i appreciate ur urgent answer because this is very important for me in my security work, thanks alot
Correct Answer by kicharle about 7 years 9 months ago
I think, you can get the list of port numbers from google.
But you can try the following:
class-map type inspect im match-any yahooandmsn
match protocol msn-im
match protocol yahoo-im
policy-map type inspect im yahoomsn
parameters
class yahooandmsn
reset
With regards
Kings
Overall Rating: 5 (1 ratings)
Correct Answer
kicharle Mon, 10/19/2009 - 02:44
parameters
class yahooandmsn
reset
With regards
Kings
