Please Help ! Cannot use RDP over VLAN
Oct 19th, 2009
Dear Experts,
I have one 2 PCs in my branch office are connected through WAN link Layer 2 (1MB) to my Headquarters.
Although I can Ping and Telnet from the 2 PCs to my Headquarters Network and I can connct through RDP from any PC in my Headquarters to both PCs, I CANNOT connect from any of the two PCs to any PC in my Headquarters or Joint the Domain from my branch or even copy afile from Headquarters to branch office PC.
Following is the config of my branch office switch:
Building configuration...
Current configuration : 1864 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname HC-DFM-SW-01
enable secret 5 $1$ETyR$JSZk4Xw4d2tZ2IkdkAp9S.
enable password 7 0005150E07095B5659
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
switchport voice vlan 20
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface GigabitEthernet0/1
switchport mode trunk
interface Vlan1
no ip address
interface Vlan30
ip address 172.17.130.101 255.255.255.0
no ip route-cache
ip classless
ip http server
control-plane
line con 0
password 7 060709294F6E40503B57
login
line vty 0 4
login
line vty 5 15
password 7 08204A460A394C5E2C
login
end
John Blakley Mon, 10/19/2009 - 06:31
  • Purple, 4500 points or more
I don't see anything on the switch that would cause this problem. Is there a firewall on the headquarters side that could be blocking you? It would make sense that headquarter's pcs can connect out since most firewalls allow traffic outbound, but block on the inbound side (which is the side that your remote branch is coming from).
HTH,
John
ktwaddell Mon, 10/19/2009 - 06:36
You need to provide the layer 3 configs, whatever is stopping you we need to look at layer 3 1st.
So a network diagram along with configs would help alot
Cheers
kev
