Migrate from 3 digit to 4 Digit extensions
Oct 19th, 2009
We are in the process of migrating from 3 Digit to 4 Digit Extensions. We are running call manager 5.x is there a way to use bulk administration to update the extensions?
Brandon Buffin Mon, 10/19/2009 - 06:44
Here's one way to do this:
1. Use the BAT export utility to export all details of your phones to a CSV file.
2. Modify the extensions in the CSV.
3. Delete all existing phones.
4. Use BAT to import the updated CSV file.
Be sure to make a copy of the original exported CSV file before modifying. It would also be a good idea to test with a couple of phones before updating all devices.
Hope this helps.
