Internal error in communication channel - browser problem?
Oct 19th, 2009
  • Bronze, 100 points or more
I have still the problem with the error "Internal error in communication channel" under LMS 3.2 with three Win2k3 servers.
In 90% of all tries to configure credentials under common services I get that error.
I tried the same change of credentials directly on the server, accidental with Firefox. And it worked!
After that I tried the next credentials on my workstation with firefox, and it worked, too!
Firefox is version 3.5.3.
IExplorer is version 6.0.2900.2180 SP2.
I installed IE v7.0.5730.13, it worked, too!
Any ideas what I can do to use IExplorer because the IE v6 is our standard...
Thanks!
Joe Clarke Mon, 10/19/2009 - 07:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Sven Hruza Mon, 10/19/2009 - 07:24
I know that thread, but I can't see the context with my applications.
I have to say, that I do the service for five LMS 3.2 installations and four of them are single server installations.
All applications have the same problem.
On all servers I use the FQDN, but that in every corner and on every certificate.
So I can't believe that the FQDNs are the problem?!?
The procedure on the server of configuring credentials is everytime the same, I think.
And sometimes it works great with IEv6.
So I can't understand where the failure happens in that construct...
Joe Clarke Mon, 10/19/2009 - 07:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you can reliably reproduce the problem, and you've gone through the check list I already laid out, then you should open a TAC service request so additional debugging can be performed.
