transfer to international #
Oct 19th, 2009
Customer can tranfser to any North American number just fine.
When trying to transfer to an international number it drops the call right in the middle of dialing the numbers.
Any reason for this, or a command to control that?
Maulik Shah Mon, 10/19/2009 - 13:18
  • Silver, 250 points or more
Seems like a dial plan matching issue - few questions:
- Do direct calls to international #s work?
- what is the exact string they are dialing
- can we get their current config
7bridgesol Mon, 10/19/2009 - 19:47
direct calls work no problem.
I did check under telphony-service.  This is what I have listed.
transfer-system full-consult
transfer-pattern 9........... blind
secondary-dialtone 9
Should that be
transfer-pattern 9T blind
sensitive info.  but dial-peers look like this.
dial-peer voice 1 voip
description **incoming call from sip trunk**
translation-profile incoming voicemail-aa
destination-pattern 60.
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target ipv4:10.20.30.5
incoming called-number .%
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
description **outgoing to sip trunk**
translation-profile outgoing pstn-outgoing
destination-pattern 9[478][127][248][2-9]......
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 3 voip
destination-pattern 91[2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 99 voip
session target ipv4:192.168.201.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 4 voip
destination-pattern 9011............
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 5 voip
destination-pattern 90T
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 6 voip
destination-pattern 911
voice-class codec 1
dtmf-relay rtp-nte
Maulik Shah Mon, 10/19/2009 - 21:12
The transfer-pattern 9T blind is what you need - go ahead and add that in.
