CRS Admin Unknown
Hi All,
I have found the following procedure to recover the CRSAdmin but I had a couple questions. Does this only redirect the HTTP page to the Startup wizard and keep all other configuration untouched? By running this does it have any affect on the production system? Meaning is it save to run during the day or should I wait until after hours.
Use the CET tool to force the intialization wizard again. You can do this by following this:
1 . Start the Config Object Browser.
Go to start -> run and type "cet"
(or run cet.bat in the "C:\Program Files\wfavvid" directory )
2 . Select "" from the config object type tree and double click on the row at the right pane.
3. Select the "" tab and change the Setup State from "DONE" to "FRESH_INSTALL".
4. Restart the node manager.
5 . Login to the Appadmin with Administrator/ciscocisco credentials.
6 . This will lead to the initial setup
Abdulbaseer Mohammed Sun, 10/25/2009 - 21:54
It depends on at what point you stop it.
If you are doing this to any production systme and unsure I always recommend run a backup and yes do it after hours or non production hours.
Though this is a smart short cut to recover.
