Paolo Bevilacqua Mon, 10/19/2009 - 07:33
You can use the VG-224s in H.232 or SIP mode, not SCCP. Meaning, you will not be able to configure the ports ephones, hence will have limited features.
You will also find that si more economical to use real ephone and not not analog gateways
anbatist Mon, 10/19/2009 - 07:45
O.K.
You can say that the answer is yes, but if I want to to do that, I need to define several dial-peers (SIP/H.323).
Paolo Bevilacqua Mon, 10/19/2009 - 07:49
Yes. However when all ports are active, chances are you will be exceeding the performances of the 2801.
Please remember to rate useful posts with the scrollbox below.
