Proposed Lab for CCNP Studys;)
Oct 19th, 2009
Can you tell me if you think this is a well rounded lab setup for CCNP. I think it covers all bases;) Well i hope;)
Switches
3550 Enh. (L3) - Layer 3 switch
2950 std. image - layer 2 switch
2950 Enh. Image - Layer 2 switch
Routers
2610xm wic 2t
1721 wic 2t x2
837
Its a 4 router 3 three switch approach, all supporting 12.4.
Do you think this will be enough to cover the CCNP labs?
Many Thanks,
Bill
Overall Rating: 1 (1 ratings)
billyinkin Mon, 10/19/2009 - 09:49
aacrcisco do you think im a multi millionare? hahaha, i am working on a budget of around 500 pounds, or 800 dollars;)
Cheers;)
Bill
aacrcisco Mon, 10/19/2009 - 10:40
Haha,
i just brought some Cisco switchs/routers
2x 3550'sEMI=$300 each
2x 2610xm's= 250 Each
2 x 3640's =200 each
so but another 3550 and as many 2610XM's as you can. that should get you started.
I got the 3640's to support MPLS, but they wont run advanced IP services 12.4T IOS
2610xm's or better.
billyinkin Tue, 10/20/2009 - 05:11
you was right the first time as 2610xm's do support advanced ip services;))
billyinkin Tue, 10/20/2009 - 05:49
also the 2610xm supports MPLS;) its not actually stated but it does as of 12.3;))
billyinkin Tue, 10/20/2009 - 05:55
So i have revised my lab setup now;))
2x 2610xm advanced ip services, ad sec. mpls support
2x1721 IP/FW/IDS/ Plus IPSEC 3DES
2x3550 enhanced image- L3 support
2x2950 enhanced image
What do you think of this?
Bill
billyinkin Wed, 10/28/2009 - 05:07
Just managed to get 4 2621xm's for 100 pounds each with wic-2t and a isdn interface. the 2621xm also has two fast ethernet ports;))))))))
Yay;)))
Bill
