Bridge Mode over T1 - Even possible?
Answered Question
Oct 19th, 2009
I have two 2600 routers, each have a fast ethernet port and a wic1-dsu-t1. I have connected the T1 cards together with an Rj48c cable. When I configure those interfaces accordingly they are up/up and if I assign addresses they can ping back and forth. What I'm trying to do now is bridge the fast-ethernet ports to the wan connection on each router. When I do so all the ports appear up/up, but nothing is talking across. Below are the configs of router1 and router2. Router1 will be connected to a switch on my LAN. Router2 will have a computer connected via crossover cable. I'm trying to see if bridging the two routers together will allow the host connected to router2 to see the LAN conected to Router1.
My boss is the one that wants me to see if this is even possible (I have no idea why.) Can anyone tell me what I am missing?
ROUTER1:
version 12.3
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
bridge irb
interface FastEthernet0/0
no ip address
duplex auto
speed auto
bridge-group 1
interface Serial0/2
no ip address
service-module t1 clock source internal
bridge-group 1
interface BVI1
ip http server
ip classless
bridge 1 protocol ieee
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
ROUTER2:
version 12.3
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
bridge irb
no ip address
duplex auto
speed auto
bridge-group 1
interface Serial0/1
no ip address
bridge-group 1
interface BVI1
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Correct Answer by Richard Burts about 7 years 8 months ago
Patrick
It is certainly possible to bridge Ethernet frames from an Ethernet interface through a serial interface, over a serial link, to a serial interface on another router, and then to the Ethernet interface of the other router. A device in the LAN of one router should be able to communicate with a device in the LAN of the other router - assuming that both devices are properly configured (as members of a common subnet).
Given what you show in the original post I would suggest that there is a more simple config that is possible (and probably desirable):
- remove the command for bridge irb
- remove the interface BVI1
- insert the command no ip routing
Let me also make the point that while it is certainly POSSIBLE to configure bridging to link 2 LANs over a serial link, it is generally not advised to do so.
Rick
Correct Answer by Peter Paluch about 7 years 8 months ago
Patrick, Giuseppe,
I have made a simple topology virtually identical to what the Patrick has set up, and I did not have any problems running a bridge over a serial line with HDLC or PPP. The configuration of a single bridging router was:
bridge irb
interface Fa0/0
bridge-group 1
no shutdown
interface Serial1/1
bridge-group 1
no shutdown
This worked just fine:
R2#show bridge
Total of 300 station blocks, 298 free
Codes: P - permanent, S - self
Bridge Group 1:
Address Action Interface Age RX count TX count
c003.4948.0000 forward Serial1/1 40 57 84
c000.4948.0000 forward FastEthernet0/0 40 89 54
Best regards,
Peter
Overall Rating: 5 (5 ratings)
Correct Answer
Giuseppe Larosa Mon, 10/19/2009 - 10:43
  • Hall of Fame,
    Founding Member
Correct Answer
Peter Paluch Mon, 10/19/2009 - 12:45
  • Cisco Employee,
Patrick, Giuseppe,
bridge irb
interface Fa0/0
bridge-group 1
no shutdown
interface Serial1/1
bridge-group 1
no shutdown
R2#show bridge
Bridge Group 1:
Best regards,
Peter
Correct Answer
Richard Burts Tue, 10/20/2009 - 10:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Patrick
Rick
Peter Paluch Tue, 10/20/2009 - 10:45
  • Cisco Employee,
Hi Rick,
I agree that the BVI1 interface is not needed in this example. However, my experimental network did not work without the "bridge irb" command. I haven't tried deactivating the IP routing, though. I'll give it a try.
Best regards,
Peter
Peter Paluch Tue, 10/20/2009 - 11:03
  • Cisco Employee,
Hello Rick,
Thanks for your hints! So I've come to these conclusions:
1.) Either the "ip routing" is left active, and then you need to configure the "bridge irb", otherwise the bridging is not operational
2.) Or the "ip routing" is deactivated and the bridge will work without any further configuration
Thanks!
Best regards,
Peter
epatrickwhite Mon, 11/23/2009 - 16:34
Thank you all for the info.  I was able to take this information to answer my question.
