Cisco SDM - VPN wizard don't start
Oct 19th, 2009
I have problem with Cisco Router and Security Device Manager",
version 2.5. I need create Easy VPN Server by Wizard, but here is a problem,
when I click on "Launch Easy VPN Server Wizard" button, nothing happens.
The same problem is in other VPN wizards. But wizards for NAT, Firewall, QoS, etc. are OK.
Currently I'am running Windows XP SP3 and the lastest JRE 1.6.16. I tried older versions of JRE, but there is the same.
I also tried change memory heal size with this parameter -Xmx320m, and problem still exists.
Thank You or your help!
Overall Rating: 5 (1 ratings)
