Cisco ISO Loading to 4900 Switch.
Oct 19th, 2009
Hi All,
I am currently running cisco IOS and want to load fresh Cisco IOS. I connected the G1/2 into the TFTP server computer. The TFTP server interface is 10.0.0.2. I am unable to assign the ip address to the G1/2. how can I do the file tranfer from the computer to the switch bootflash and load the switch using the new image.
Thank you,
Siva
Overall Rating: 5 (2 ratings)
Lucien Avramov Mon, 10/19/2009 - 12:49
  • Red, 2250 points or more
you need to make g1/2 a non switchport.
issue no switchport on the interface g1/2 and then assign an ip.
sivaprakasam81 Mon, 10/19/2009 - 13:24
Thank you. I have done the tranfer of IOS image via VLAN1. I am unable to delete the VLAN information on the Switch. It is sandalone Switch. Not connected with any switch.
Cisco 4900 Switch.
Switch#dir cat4000_switch:
Lucien Avramov Mon, 10/19/2009 - 13:29
Issue a dir all command and find out where the vlan.dat is.
iyde Wed, 10/21/2009 - 04:23
  • Silver, 250 points or more
And be aware that VLAN1 cannot be deleted. It's the default VLAN.
