Very simple hardware question
Oct 19th, 2009
Hey all,
I'm a CCNA without any real world experience. I'm trying to find a WIC for a 2801 that has at least one gigabit interface (fibre). I've been digging around for half an hour online, and most of what I find is HWICs, which it looks like the 2801 doesn't support. What do I need?
Thanks in advance. ;)
Overall Rating: 5 (1 ratings)
Lucien Avramov Mon, 10/19/2009 - 15:11
  • Red, 2250 points or more
I did read your post too fast.
There is no HWIC for the fiber for 2801.
You need to upgrade the router for that feature.
Sushil Kumar Katre Mon, 10/19/2009 - 20:54
  • Gold, 750 points or more
Hi Anthony,
The links which Lucien has sent states that this GE HWIC is supported on a 2801 router with IOS 12.4(15)T9, IP Base, Table 2.
As far as HWIC slot on 2801 is concerned you get -
2 slots which support HWIC, WIC, VIC, or VWIC
1 slot which supports WIC, VIC, or VWIC 1 slot which supports VIC or VWIC
So to me it looks like HWIC-1GE-SFP is supporte on 2801 router.
-> Sushil
iyde Wed, 10/21/2009 - 05:35
  • Silver, 250 points or more
Correct, the HWIC-1GE-SFP is supported with 12.4(15)T9 or newer. But as Guiseppe writes, you shall not expect to have a full 1GE throughput.
Giuseppe Larosa Tue, 10/20/2009 - 01:37
  • Hall of Fame,
    Founding Member
Hello Anthony,
be aware that a GE port on a C2801 would be just nominal : router performance are far lower then a GE port.
It could just solve an interconnection issue.
Have you got a free FE port on the device?
Hope to help
Giuseppe
