General Security Context question.
Answered Question
Oct 19th, 2009
Greetings All,
Is it possible to have the interface of two or more context on the same vlan?
For example context 1 has gig0/1.1 on vlan 10 and context 2 has gig0/1.2 on vlan 10 as well.
Correct Answer by Jon Marshall about 7 years 6 months ago
Merrylle
Yes, contexts can use the same vlan. In fact this is a quite a common setup where the outside interfaces of the contexts are all in the same vlan and the dmz and inside interfaces are in separate vlans.
So you can have one IP subnet/vlan for all your outside interfaces.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 10/19/2009 - 20:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Merrylle
Jon
