WLC
Answered Question
Oct 19th, 2009
I have WLC and it is not coming green on the topology service when the
SNMP v2 or v3 is enabled. But it shows green when I enable SNMP v1 on it.
How can we set SNMP v2 or v3 on WLC to have the device come green in Topology as well?
-Thanks
Correct Answer by Joe Clarke about 7 years 8 months ago
Yes.
Overall Rating: 5 (2 ratings)
Joe Clarke Mon, 10/19/2009 - 15:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You must enable SNMPv1 on the WLC. That is required to manage it if you are using community string-based SNMP. LMS 3.2 has converted to mostly using SNMPv2c, and only falling back to v1 if absolutely necessary.
georgeef1 Tue, 10/20/2009 - 07:33
Thanks Jclarke,
One last question, if I upgrade to LMS 3.2 can I use the SNMP v2 option on my WLC?
-Thanks
Correct Answer
Joe Clarke Tue, 10/20/2009 - 08:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes.
