BGP Config for 2-DS3 links
Oct 19th, 2009
I have a location with cisco7206VXR router.i would be terminating 2 ds3 MPLS circuits on this router.what extra lines of configuration i need to do in BGP.like maximum-paths 2, is this command neccesary?what else do i need to add?
thanks
Overall Rating: 5 (2 ratings)
Edison Ortiz Mon, 10/19/2009 - 19:04
  • Hall of Fame,
    Founding Member
If you are receiving the same route from both DS3 circuits and you want to CEF load-balance the flows, maximum-paths 2 allows you to insert 2 best routes from BGP into the routing table - the default is 1 best route.
You may also want to avoid this router from becoming a transit router so make sure to advertise routes that are originated on this router.
This URL provides a sample config:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
Edison.
azharuddininamdar Mon, 10/19/2009 - 20:54
Hi Edison,
i would be learning the same routes on both the links,so i will have to configure max paths2 to have 2 best routes installed in my routing table.thanks.is it the same way for maximum-paths 3,4,5 as well?
i have both links delivered from one service provider.there shouldn't be any chances of my router becoming transit router. right?
Edison Ortiz Tue, 10/20/2009 - 05:26
  • Hall of Fame,
    Founding Member
Yes.
If both links connect to the same BGP AS, then you won't become a transit router. If both links connect to a different BGP AS, there is a potential that you might. ISPs usually protect themselves from this kind of issue but the customer should also implement policies as well..
Edison.
