Cisco API for personal directory and fast dial
Oct 19th, 2009
Hi All
Does anyone know of any documents from Cisco covers API for personal directory and fast dial. I am trying to import personal directory and fast dial into CUCM 7.1 using a bulk process. Anyone know of a procedure to do it?
virverma Tue, 10/20/2009 - 00:33
The DirExport is the part of DMA that extracts user data from the directory and creates
CSV files of that data. The CSV files get used to populate the database. All the user
information gets migrated from the directory to the database.
When you upgrade from Cisco Unified CM 4.x to Cisco Unified CM 5.x or later, the following
get migrated.
•Endusernumplanmap .CSV
When running the DMA, Fast Dials information from the directory is exported as the
ciscoccnocFastDialEntry.csv by the DirExport module of DMA for all directories including
