Input and Output error in switch interface
Rupesh Kashyap
Hi, I have server connected with the switch-A. I am facing server slow response problem. I have initiated ping (datagram-1000, repeat-1000)of the server IP from other switch. Ping output is 100 % and no drop, but I m getting few Input and Output error on Switch-A. What is the meaning of this? Please find the below log.
Switch-A#sh int gi 1/35
GigabitEthernet1/35 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0012.4302.639a (bia 0012.4302.639a)
Description: Link to ANLITSLASV01
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output never, output hang never
Input queue: 0/2000/292/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 109000 bits/sec, 18 packets/sec
1604701955 packets input, 1998221926091 bytes, 0 no buffer
Received 1475209 broadcasts (1474051 multicasts)
20 runts, 0 giants, 0 throttles
51 input errors, 4 CRC, 0 frame, 241 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
544362665 packets output, 126784921530 bytes, 0 underruns
67 output errors, 0 collisions, 2 interface resets
ohassairi
Level 5
Level 5
we can note that you have this:
Input queue: 0/2000/292/0 (size/max/drops/flushes); --> 292 drops
241 overrun
i think this is due to this: input flow-control is off, output flow-control is on
may be we need to have flow-control on for both directions.
can you force it in your NIC and in switch interface?
Is Input or output Flow-Control effects the communication?
