duplex mismatch problem
Oct 19th, 2009
I have connectivity like this:
customer switch forced to 100Mbps/Full duplex----------My end ME-3400-24TS-D configured for Auto negotiation.
ME-3400 negotiating with 100Mbps/Half duplex.
Customer facing CRC. Forced ME-3400 to 100Mbps/Full duplex, but link is not coming up.
ME-3400 IOS is me340x-metroaccess-mz.122-44.SE.bin
Is it bug related issue?
SKRAO
sjamison76 Wed, 10/21/2009 - 07:56
Have had the same problem. Make sure you both force the link to the speed/duplex you want.
If you still have CRC issues on the line, usually its a cable issue. You can use the following command to test the cable.
This does take the port down when you do this for a few seconds:
'test cable-diag tdr int xx/xx'
'show cable-diag tdr' for results
sivakondalarao Thu, 10/22/2009 - 09:29
After forcing both ends to 100Mbps/Full Duplex, link is showing down.
SKRAO
summerd Tue, 12/08/2009 - 06:00
Were you able to fix this issue so that both sides could be hard-coded to full duplex? I'm having the same problem...
Did you try the cable commands to make sure the cable wasn't the problem?
skrao_mandalapu Wed, 12/30/2009 - 03:55
Hi SummerD,
No, we didn't check the cable. It is customer connectivity issue with us. I don't know how that ticket is closed.
Siva K
jdcardenas Wed, 03/17/2010 - 09:41
Hi guys,
I´ve been having the same problem whe trying to bring up a link between a gigabitethernet port using the UTP connector and a fastethernet port on a Huawei SW...the only way it works in full duplex /100 is when both sides are auto.
any idea whats the cause of this behavior?
summerd Wed, 03/17/2010 - 09:47
My situation ended up being the wrong cable, layer 1- easy fix
