Client NAT in CSS11500
UHansen1976
I'm currently redesigning my portal infrastructure and as such, I need to redo a few things on my CSS. But I can't seem to find anything about Client-NAT on the CSS. I need to NAT/PAT external sessions to an inside RFC1918-address. The config below simply passes the original src.ip through and consequently the session is blocked by the firewall. So far I've been unsuccessfull in finding the proper documentation, so I'm hoping someone here can help me get started.
owner BK019TF
content BK019TF-SSL
vip address a.b.c.d
add service SSLMODULE1
port 443
protocol tcp
active
content BK019TF
redundant-index 142
advanced-balance sticky-srcip
port 4433
protocol tcp
vip address a.b.c.d
add service Misys-ben-3
add service Misys-ben-4
active
/Ulrih
Source groups are used on CSS to NAT the source ip addresses. There could be two scenarios
1. A connection is open to the server.
In this case you need 'add destination service'.
2.The server opens the connection. In this case you need 'add service ...'
Following example will give you some idea of how to implement src NAt with CSS
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a0080093dff.shtml
Syed Iftekhar Ahmed
Syed Iftekhar Ahmed
Just what I needed. A thousand thanks
/Ulrich
