ASA no 3DES
Answered Question
Oct 20th, 2009
Dear All,
I had ASA 5505 not 3Des so i would like to upgrade to 3Des how can i upgrade it?
Best Regards,
Rechard
Rechard,
On the page I gave you - at the top in the big blue box is says
Licenses Not Requiring a PAK
If you do not have a Product Authorization Key (PAK), please click here for available licenses.
Available licenses include Evaluation/Demo Licenses, Cisco ASA 3DES/AES, PIX Firewall 3DES/AES and DES Encryption, Cisco Services for IPS, and Cisco Unified Communications Manager Version Upgrade licenses.
So you need to click on "here for available licenses"
The scroll down the page and you will see "Cisco ASA 3DES/AES License"
Fill out the form and you will get your activation key for AES/3DES
HTH>
Overall Rating: 5 (1 ratings)
nareth_norung Tue, 10/20/2009 - 17:30
Dear Sir,
thank you for your help!!!
when i go the website that you gave me it requite Product Authorization Key (PAK) i don't have the serial number....
Best Regards,
Rechard
Correct Answer
Rechard,
HTH>
