Error with Cisco 3120 Blade Switch License
Oct 20th, 2009
Hi all.
I'm suffering 'cause i've a problem with my switches licenses.
i have four 3120 cisco switches for hp bladesystem. The problem is i generated my *.lic license files and now i found an error in the information (S/N) i used to generate them.
I need to erase the old licenses and generate new ones or at least modify the existing ones...
Do you know what solutions do i have? or at least where should i point my search???
Thank you very much in advance.
Best regards,
E. Martín.
