10-20-2009 02:20 AM - edited 03-15-2019 08:08 PM
I have some questions. Can anybody answer for them in the asked order?
1)What adventages will I reaceive with integration Unity Connection and CUCM?
2)Could I integrate Unity Connection 7 and CUCM 6.1?
3)Could I use Unity Connection for sending/receiveing fAXes by mail?
Thank you!
10-20-2009 04:25 AM
Ans: Unity Connection is a great tool for VoiceMail/Unified Messaging as well as it functions pretty well as an Auto Attendent
Ans. Yes, we have one of our clients in the same configuration.
3.Could I use Unity Connection for sending/receiveing fAXes by mail?
Yes, however you need to integrate it with a Fax Server
You may find this guide helpful:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/design/guide/7xcucdg080.html
Hope that helps, please rate if it helps
Sam Wilson
10-20-2009 01:56 PM
Can I send FAXes to mailboxes without using/buying additional servers like FAX Server?
