10-20-2009 02:26 AM
In LMS 3.0.1 am receiving unresponsive alerts on my VRF interface,though it is up and running.
Solved! Go to Solution.
10-20-2009 11:13 AM
If you unmanage the interface, then DFM will not report if it goes down. However, if you only unamanage the IP, then DFM will report when the interface goes down.
10-20-2009 08:32 AM
In order for DFM to be able to manage an interface, it must be able to ping the IP address on that interface. If the IP is not ICMP-reachable, then you need to unmanage that IP in the DFM Detailed Device View. To do this, go to DFM > Device Management > Device Details, find the IP in the IP branch of the tree, and set its managed state to false.
10-20-2009 09:10 AM
Hi Joe,
These interfaces are live i dont want to make it false,i want the status if they goes down or up,they are asosciated to MPLS VRF so that's the reason LMS is not able to ping,To ping these interfaces from the switch itself then i have to use a commmand
ping vrf test 10.10.10.l I can't ping by normal ping command.
what the alternate solution.
10-20-2009 09:13 AM
There is no alternate solution. If DFM cannot ping the IPs, then you must unmanage them. The interfaces will remained managed, though.
10-20-2009 11:05 AM
Hi Joe
when the interface truly goes down,it will reflect in DFM also after unmanaging the ports??????????????
10-20-2009 11:13 AM
10-23-2009 06:26 AM
Thanks Joe,
The issue is solved,
10-20-2009 11:37 AM
Hi Joe
10-21-2009 12:52 AM
Joe
sorry the thread was sent again,
I will do it and i will close the case,
